Error 1 occurred at Scan From String (arg 1)
Hey,
I'm working on a project where I'm using LabVIEW.
The objective is to send numbers to LabVIEW via Bluetooth. In LabVIEW, these numbers should create a graph but are not doing so. The error is:
Error 1 occured at Scan From String (arg 1)
Possible reason(s):
LabVIEW: An input parameter is invalid. For example, if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Attached is my project , the error 's printscreen and a file from RCOM Serial where it can see the numbers that I want.
(5,207 Views)
What is the data coming out of the VISA Read?
If you are using the termination character (which you should be), then just set the Bytes To Read to something larger than you would expect to read, line 15 or 20.  The VISA Read will stop reading when it finds the End Of Line character (assuming you don't change what the termination character is).
(5,196 Views)
