Error 1003 occured while craeting VI interface to LabWindows.
I am facing while creating labView VI interface to LabWindow/CVI Instrument Driver. I am getting an error code of 1003 which states :
Error 1003 occured at Invoke Node in Import Driver.vi -> Import Driver.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located.  Open the VI in LabVIEW using File>>Open and verify that it is runnable.
Method Name: Run VI
VI Path: C:\Program Files\National Instruments\LabVIEW 8.6\project\_DriverCtoLV\Interface\FC_Interface_Main.vi
I am using LabView 8.6 version and have installed Import Instrument Driver Wizard version 1.2.
Please do let me know if someone has already faced such situation and the remedy.
Thanks in Advance,
Vivek
(4,485 Views)
Hello Vivek,
      What CVI instrument driver are you attempting to run the tool on?  Does it follow the VXI Plug and Play specifications?  If possible, please post the CVI driver source code.
Cheers,
NathanT
(4,467 Views)
HI Nathan,
Basically we are working on Agilent Omnibar drivers that downloaded from this site : http://www.home.agilent.com/agilent/facet.jspx?cc=IN&lc=eng&k=J1409A&sm=g&t=80045.k.1 that I suppose follows .the VXI Plug and Play specifications.
But before we could have started working on this, our conversion thing didn't work. So looking for possible reason or any other version of the LabVIEW Instrument Driver Import Wizard.
Looking Forward.
Rgards,
Vivek
(4,465 Views)
May be my first post didn't classify my problem properly as I hadn't communicated very well. Sorry for the inconvenience.
Actually I have downloaded the available LabVIEW Instrument Driver Import Wizard(ver: 1.2) from ni.com. It enables the Create VI Interface to LabWindows/CVI Instrument Driver option in Tools >> Instrumentation menu that itself is a VI. I am going for that option in LabView 8.6 and finding it broken with an error message of error code 1003. Please find the description below: Error 1003 occured at Invoke Node in Import Driver.vi -> Import Driver.vi.ProxyCallerPossible reason(s):LabVIEW:  The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located.  Open the VI in LabVIEW using File>>Open and verify that it is runnable.Method Name: Run VIVI Path: C:\Program Files\National Instruments\LabVIEW 8.6\project\_DriverCtoLV\Interface\FC_Interface_Main.vi I hope this time I haev communicated the issue well.  Please do suggest any solution for this. Thanks in Advance,Vivek
(4,463 Views)
Hello Vivek,
          I ran the 1.0 version of the tool in LabVIEW 7.1 and have attached the wrapper (mass compiled in 8.2.1).  Please take a look at the conversion report and address those issues as needed.  I will try to reproduce the 1003 error you are seeing in LabVIEW 8.6.
Cheers,
NathanT
(4,436 Views)
Hello Vivek,
         I installed LabVIEW 8.6.1 on a clean image and then installed the 1.2 version of the conversion tool and it worked fine.  I have attached the wrapper instrument driver.  Do you have multiple versions of LabVIEW on your machine?  Have you had the tool installed in a previous version of LabVIEW?
Cheers,
NathanT
(4,434 Views)
Yes Nathan, I also tried in same way. I uninstalled everything belonning to NI and install it back and now it's working fine. I don't know why the things didn't work that time(might be some versioning ismsues). Anyways thanx for your valuable suggestions and help.
Thanks a ton.....
Vivek
(4,421 Views)
