Error 106 from SCPI Measurement not Found when creating a new trace
Hi All,
I am getting an Error 106 for Measurement Not Found when I am creating a new trace. I am new to using a PNA and PNA labview drivers. I was wondering if my setup is wrong or if anyone has an example program that works with measurements and creating new traces. The LabVIEW example given doesn't take measurements and uses ActiveX controls that only display Driver and Equipment Information.
I am using the E8364C PNA with the PNA-X LabVIEW Driver. I am connected through USB but I can also switch to GPIB.
https://www.keysight.com/us/en/lib/software-detail/driver/pna-and-pnax-series-microwave-network-anal...
(1,297 Views)
If I follow that link I get a driver released in 2021 that does not support your VNA.
Here's a link to the driver on IDNET that supports your model - https://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=04755C3EB05960C5E0440003BA7CC...
If that doesn't work, then look at the necessary SCPI commands to complete your task.  Post your code if you get stuck.
Craig
(1,258 Views)
