Error 1073807298 on VISA write
I also got error 0x4000FFC2 as negative.
I get it in an application to send firmware to TMS320C2000 through RS232.
The reason is that for each byte I send, I get the same byte in response.
BUT, not the last byte. I get no response from it, which creates this error. So I did as you did, I remove this particular warning.
Message 21 of 22
(2,791 Views)
I can also confirm that setting the buffer size using the VISA Set I/O Buffer VI fixed my problem interfacing with a USB to serial converter.
Thanks Jim!
Message 22 of 22
(2,150 Views)
