Error -1073807300 occurred at property node(arg1) in VISA Configure Serial Port; Possible reasion : VISA: (HEX 0xBFFF003C) Insufficient system resouces to perform nessary memory allocation
I move my labview application from windows2000 to windows XP computer. When i run my alliplication in a minute there had error -1073807300. I can run this application without error on windows2000 why not work with windows Xp. Any Idea to fix this error?
New computer : WindowsXP SP2, Labview 6.1, NI-VISA 3.6
Old computer: windows200 SP4, Labview 6.1, NI-VISA 3.0.1
(4,305 Views)
Hi Musha,
This error could be coming from a configuration issue on your XP machine.  Are you using the same card on the new machine, or a different one?  Are you able to communicate with it in MAX through a VISA Test Panel?  The following link may be useful:
http://digital.ni.com/public.nsf/websearch/862567530005F09C8625659A0076B772?OpenDocument
The error could also be caused by having more than one session open without knowing it.  The following page has troubleshooting tips on verifying this:
http://www.ni.com/support/labview/visa/verr5.htm
Hope this helps!
AdamW
(4,280 Views)
