Error -1073807339
Dear All
I am making application for Ethernet to RS-232 converter and getting the below error message..
"Error -1073807339 occurred at VISA Read in RS-232 Read Wrire.vi->TCP IP RS-232.vi"
can any give me solution for this.
(7,372 Views)
Timeout expired.  Which makes me think that your instrument is not sending anything back or you have a serial port setting wrong.
(7,355 Views)
thank u sir
with your help now my application is working.
Regard,
Arvind Gyali
(7,262 Views)
I'm getting this same error on a device that works on my Primary desktop, but not on my laptop. I believe it's probably a serial setting but where are those adjusted if the VIs are just using the standard VISA Open without the configuring etc? I try to run any of these examples and it just screws up within the initialize VI. When I reset the instrument the IDN* command will work the first time but thereafter when it attempts the *RST command will completely mess up the instrument and result in an unusable instrument until I power cycle it.
After erroring out in the VI, I'll try to open it in OPEN VISA Test Panel in NI MAX and get the following error:
Error opening resource:
USB0::0x0957::0x9318::MY54320347::INSTR
VISA:  (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
(6,340 Views)
