Error Hex 0xBFFF0015
I am trying to communicate with a hp infinium oscilloscope 54845A. I am using LabView 7.1. When I run the example program, it displays a time error Hex0xBFFF0015 ( see picture). I am using an Agilent 82351A PCIe-GPIB card.  When I open the measurement and automation software, the instrument appears to work properly. I have also attached the captured data when I run NI-spy program.
Thanks in advance for your help.
(5,355 Views)
Hi
The scope data is very long.  How much data do you ask and how much do you get?
Try to read blocks of data of about 1000 measurement points in a while loop.
Or you can try to extend the timeout time to a few minutes and do something else during the read.
greetings from the Netherlands
(5,341 Views)
(5,332 Views)
That is a problem with these "deep memory" scopes.  even with GPIB speeds your looking a a long time to transfer an entire record from the scope.
In most cases you don't need the whole record.  The scope is capable of making just about any measurement that you could need so its often faster to just return the measurement that you are interested in.  If you find that you do need to operate on the entire record This K Base  article is a must read! And, as was already suggested, you should consider reading the record in blocks and operate on the blocks to reduce memory needs that will both bog down your processor and slow down the data transfer from GPIB to memory.
(5,316 Views)
Thank you for your replies. I am only reading one single point. I am using the hp3458a instrument labview drivers and I am running the example program called "getting started" which only reads one data point.
I have run the internal GPIB debugging code for the oscilloscope and there it shows that the oscilloscope can not identify the header on the LabView program, because although the header is correct is not defined for this oscilloscope.
(5,294 Views)
