Error code -200088,-200284
Hi, I have taken a labview code, when I run it, I faced this error. If I want to fix this, what's more information that I should give? Picture of error is attached。Thank you.
(3,855 Views)
One error says that the task is invalid.  The other claims there is no data available to read.  Mind sharing your VI so that we can help diagnose your problem?
(3,852 Views)
