Error in NI IVI Driver setup for Tektronix TDS210 and LV 2010
Hi
After running NI IVI driver setup for Tektronix TDS210 and LV 2010 I got Fatal Error.
Bojan
 ,23702i2E5C345B731A3909
(3,566 Views)
Do you see the same issue if you try installing the LV2009 driver?  You can try installing LV2009 and them copying the files over to LV2010 instr.lib
(3,542 Views)
The same error is also for other instruments, but yes, I can install LV2009 drivers, copy then to LV2010 instr.lib remove LV2009 map and recompile to LV2010.
Thank you
Bojan
(3,524 Views)
Thank you for reporting the error.  We are working on resolving the issue.
(3,511 Views)
