Error - session handle nor valid for ivi
Hi All
I have posted this question in existing thread also I guess.
 I am trying to control TDK lambda power supply through LabVIEW using IVI drivers.
logical name set in a MAX is same as what I am giving in VI to InitializeWithOptions.vi . However I am ending up with this error "IviDCPwr Initialize With Options.vi<ERR>
Primary Error: (Hex 0xBFFA1190) The session handle is not valid."
Not sure why this error is coming.
 Can anyone help me with this error?
(5,707 Views)
You might be using an IVI-COM driver and trying to use IVI-C Class driver VIs without having installed the IVI-COM adapters.
As mentioned in the knowledge base below The IVI-COM adapters are included with IVI Compliance Package 3.2 and later, but must be enabled in the installer's feature tree.
IVI-C Class Driver Support for IVI-COM Specific Drivers
http://digital.ni.com/public.nsf/allkb/5499F9DBD07522F686256F260066BA86?OpenDocument
duplicate post
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/TDK-Lambda-Power-Supply-error/m-p/3118149#M68...
(5,689 Views)
Hi
Thanks for the reply. From where exectly I ahve to enable it in installers feature tree? I am not able to find it..
Also how can I come to know whether i am using IVI-COM drivers or IVI -C drivers.
From MAX when I ahve configured I ahve selected IVI- C drivers only.
(5,665 Views)
