Error using VISACOM with the last versions of NI 488.2
Since the NI 488.215.0.0 drivers, the VisaCom Library doesn't work on GPIB. on Windows 7 and on Windows 8.
The "FindRsrc" function doesn't return anything.
Dim ResMan As New ResourceManager
        Dim AdrGPIBVisa() As String = Nothing
            AdrGPIBVisa = ResMan.FindRsrc("GPIB0::?*")
Same  troubles also with VBIB32.dll
 ibfind("GPIB0", Id) -->  Doesnt work.
All works fine with the 14.5.0 version.
(2,984 Views)
Now, all works fine with the 17.0.0 release.
I don't understand, but it is OK  : probably a bad record in the windows register.
Regards
(2,931 Views)
