Error while loading the vi
Hi..can anyone help me fix this error..plz..i have attach the pic
Message 1 of 8
(5,159 Views)
Don't know why you posted this to the instrument control board but it seems the VI is corrupt. Is this something you wrote? If so, do you keep regular backups?
Message 2 of 8
(5,153 Views)
im sry i didnt notice the forum..actually the vi is ok..suddenly my comp hang ready. aftr i close and open it bck it shows this error.. i didnt have a backup copy of this vi.. is there any possible way i can get to open this vi... plz help...
Message 3 of 8
(5,149 Views)
i attached the vi here...
Message 4 of 8
(5,144 Views)
You don't have the automatic save turned on and you did not get prompted to recover the VI when you started? If no, then I suspect there is only a slim chance to recover it. You might try posting the VI and see if NI can do anything to recover it.
Message 5 of 8
(5,143 Views)
Hi jeyanthi,
Is this VI an executable? If so, check out the KnowledgeBase article.  If not,  you could try doing a system restore backto before the file was corrupted.  I am assuming this used to work, correct?
I hope this helps!
Kristen H.
Message 6 of 8
(5,075 Views)
Hi
This is not an executable vi... i just start developing it ..it is a graph plotting vi.. and i already did few ploting of graph and the plots are ok.
I have try the system restored but it nothg happens...stil same.. if i do restored few days b4 ..i think i have to start again... cos i just started this vi few days back...
Is it any possible way for ni to fix this corrupted vi.. pls help
Message 7 of 8
(5,067 Views)
Hi jeyanthi,
Can you see the block diagram?  I tried to load your VI and could not either.  I saw the same error.  If you can open the block diagram, by chance, try copying everything to a new VI.  Otherwise, I think you might be out of luck, unfortunately.  All I can recommend is making sure you have the autosave feature enabled and backup your code whenever possible.
I hope this helps!
Kristen H.
Applications Engineering
Message 8 of 8
(5,055 Views)
