Error with NI 9871 (Serial RS485 interface)
Hello everybody.
I am having troubles with serial comunication with this RS485 module. I checked in MAX and the ports are present in the system, but when I open the VISA test panel appears this error: VISA:  (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
The error appears even before the test interface, so I am unable to send commands.
Any guess?
Thank you!
(3,853 Views)
some other serial comm program is open?
greetings from the Netherlands
(3,839 Views)
