Errors caused from upgrading NI-488.2 to version 2.8 or newer
Errors with ibrrd & ibwrt functions after installing new NI-488 software. Going from V2.4 to 2.8.0 or even the new 3.0.2.
The program is a simple VB6 program that reads a hp dmm and writes to a voltage source.
System is a 32b Win XP using NI PCI-GPIB plug-in 488 card.
(3,562 Views)
What sort of errors?
(3,558 Views)
Here is listing from NI trace(Spy) below.
I now can see the problem using only NI software and hardware (no VB6 program).
Using only NI's communicator, I send a Query. The error in the response is when there are two - - sign characters before the value (in Yellow).
I do not get this with Ver 2.4 of the NI 488.2 drivers.
Has some default setting changed in the newer versions?
The DMM is HP3458A
(3,549 Views)
I haven't seen that before. Odd. But I haven't used NI-488 functions in quite some time in my test programs.
Have you tried using Interactive VISA applet?
(3,540 Views)
