Errors ke2000 driver in LabWindows
I am new to use of drivers for instrument control in labwindows2012.
I downloaded driver from NI (ke2000_setup.exe) and installed on Windows XP.
When I am tring to run the example given along with driver, It is showing following Errors.
undefined _ke2000_init massage for all driver function.
I checked with .fp and .h files they are in specified directory.
I included both files in project as well but the error is still there.
Thanks for help in advance.
(4,333 Views)
You need to add the lib file also.
(4,305 Views)
