Establishing connect between AQ6315-E and PC via GPIB-USB_HS
I couldn`t establish connect with spectrum analyzer AQ6315-E in MAX. For "scan for instrument" request Max returns "Instrument not found".
What about GPIB-USB-HS - it`s 100% works correctly. Could some problems with analyzer GPIB - port be? By the way, analyzer have 2 GPIB ports. But for MAX - it is indifferent wich port is connected (it show "instrument not found" in both ways). What should be reason for this?
(3,405 Views)
Accepted by topic author Serg1987
Thank`s for attention. I found my miss. The GPIB-USB-HS and analyze have the same GPIB - address. When i specified another one for analyzer - MAX correctly reveal connected instr.
Thanks.
(3,404 Views)
