Ethernet communication using VISA : Error Code 0xBFFF003E could not perform operation because of I/O Error
I'm a newbie for Labview. I'm trying to communicate with my board through ethernet cable using labview..
I created "New VISA TCP/IP Resource" and chose " Manual Entry of Raw Socket" and entered the host IP addr and Port no and all as instructed in the labview tutorial.
When I tried to communicate through MAX - VISA Test panel, I got the Error Code 0xBFFF003E could not perform operation because of I/O Error. I'm not sure what should be done for this.
I can communicate with my board using the "ping IPaddr" query using cmd. But VISA communication is not happening.
Please help me out.
Thanks & Regards
Muthu
(4,638 Views)
Hi All,
this is working now. I had given wrong port no. Then the MAX started working
Thanks for all who tried to help 🙂
(4,576 Views)
