Ethernet to Parallel Example?
Relatively  new user here. Would like to communicate with an instrument that uses a parallel port. However, the computer has no such port and am forced to use the ethernet connection with a ethernet/parallel converter. Was wondering if I could just modify the labview example for the parallel port? Thanks.
Message 1 of 1
(3,991 Views)
