Event Structure/Foot Switch
The VISA Open is in fact, optional.
Are you able to read the foot switch with your VI? Once it is detected, what do you want to do?
Message 11 of 19
(2,159 Views)
Dennis - yes I am able to read the value when the foot switch is pressed in the MagnaMike.vi. What I'd like to do is detect when the foot switch is pressed and place the value in Excel. What I don't know how to do is to detect that the foot switch has been pressed in my Event Structure (MagnaMikeMain.vi).
Message 12 of 19
(2,153 Views)
Read the switch again and again in a separate while loop. Compare each reading with the previous reading and if achange is detected signal it to a control ( write the new value in the control by a signal value write) This control then is in one of the eventcases detected for a value change. You eventually can read the new value an act accordingly on a low or high. So next toyour mainloop you have that footswitch reading loop.
greetings from the Netherlands
Message 13 of 19
(2,151 Views)
Like this?
Message 14 of 19
(2,149 Views)
No, no, no.
Why are you even playing around with an event structure? Why don't you simply do the write to file in the loop where you are monitoring the serial port? It only makes sense to have an event structure if you want to have a front panel control do a file write. Then the Value(Signaling) would go into the while loop with the serial read - not the event you are trying to fire.
Message 15 of 19
(2,145 Views)
OK, I got it. Now, how do I make my sub VI stop when the front panel stop button is pressed?
Message 16 of 19
(2,124 Views)
put the elements from your subvi in your main program.
The init before the loop after opening excel
the read inside the while
the cloase after the while.
good luck
Message 17 of 19
(2,122 Views)
Dennis & Albert, thanks for your solutions. I now have a working program but one thing eludes me. I have placed my "Quit" text button inside the While Loop but it does not quit my program. The VISA Read is waiting for a response from the Magna Mike. I have to terminate the program by using the abort button. How do I get around this? The VI is attached.
Message 18 of 19
(2,115 Views)
remove the while from your subvi.
Just let it run once and handle the error or timeout in the higher level program.
Very good that you don't want to push the abort button.
Message 19 of 19
(2,101 Views)
