Excel VBA using VISA crashing (Oct 2021)
I have been using Excel and Word to interface to test equipment (oscilloscope).
Recently (Oct 2021) Excel is crashing when I try to connect the scope (or any equipment on my GPIB bus).
    Set SCOPE1.Command.IO = io_mgr.Open("GPIB:: 12")
My code is ok as it has always worked before.
Similar code in Word is working fine --> hardware interface and VISA drivers are ok.
Looking and the bus data using Agilent Connection Expert IO Monitor I can see the the connection to the equipment is being made but Excel crashes - monitor file attached.
Before I try to roll back the Excel version I'd like to eliminate any other possible causes.  Has anyone seen similar problems lately?
D.
(3,161 Views)
Accepted by topic author DP_Apps
If you are using Excel 16.0.14430.xxxxx, VISA is probably crashing due to a bug in Excel. (I did too)
In my case I avoided it by downgrading Excel to 16.0.14326.20404.
By the way, this is a NI bulletin board, the Keysight VISA topic is out of place.
(However, this issue occurs with both Keysight VISA and NI-VISA.)
(3,110 Views)
The latest build 16.0.14827.20158 resolves this issue.
I think you can apply this update if you have the latest channel contract with Office for Microsoft 365.
(2,283 Views)
Hi Iwa6,
Thanks for this.  This has worked on for me.
D.
(2,190 Views)
