Executable can not update VISA resource (RS232)
Hello
An executable which I have prepared from a VI can not update the available VISA resource for a RS232 connection.
e.g. An UART to USB driver which I have connected to the PC is not available in the pull down menu of the VISA resources which I have implemented as control. There is no entry available.
Is there any special setup for the build process necessary
Regards
Joerg
(3,426 Views)
If you have any DLL or Dynamic Library that you will use it to connect to the serial device, you should add these ressources in the Executable Build Specification under: SourceFiles >> Always included.
Kais Mekacher
Germany - Munich
(3,412 Views)
