Executable won't run
When I boot my executable program, I get a message that this program will not function and that the full development system of labeview is required.  I have not had this problem on any other executables I have developed.  Anyone have any ideas?
(3,306 Views)
Hi
maybe you have some more info to share, this is a litllebit too little to give a meaningfull answer.
greetings from the Netherlands
(3,298 Views)
Thanks, but I did some more searching on the boards and found a similar problem.  I tried the prescribed fix and it works.  Thanks for the help anyways.
(3,296 Views)
