External Exception was unhandled while creating an object in .net
I imported the dll provided during installation Keithley.IVR.net2.dll.. (I don remember the exact name)
I tried to create an object KE2700 ke=new KE2700("resource", true, true); using C# programming language.
But I am getting an error like external exception was unhandled..
I Placed the code in try and catch block only.
My OS is windows xp. Do I need to download any specific dll for windows xp. even i tried to compile the sample program(temperature controller in VB) which comes with installation but even there I am getting the error while creating the object.
Kindly help me in this regard.
(4,673 Views)
Thank you for the reply.
The tutorial given is about controlling the instrument by C#. I went thru it but I could not find a solution. Moreover, my problem is to which dll file i need to import in order to read the temperature data from the keithley data logger of model 2700.
I am unable to create the object of the type mentioned in the above post.
(4,665 Views)
Sounds like a question for Keithley since it is their DLL.
(4,657 Views)
Ya..I hope somebody would help me in this regard.
(4,655 Views)
(4,655 Views)
Well, these are National Instruments forums. You'd have better luck talking to Keithley direct.
(4,651 Views)
