Extra FF character in serial communication
After upgrading the LabView 8.6  to LabView 2010 the following problem appeared:
The correct response to a read command is: A5FF 0201 0001 32FF 0000 0000.
But now with LabView 2010  extra FF characters are addded: A5FF FF0201 0001 32FF FF00
What is happening. Can you help me with this problem ?
Manuel
Message 1 of 13
(4,396 Views)
please send the offending vi. I don't see a difference without it.
Maybe you have integers of the wrong data type
greetings from the Netherlands
Message 2 of 13
(4,393 Views)
This is the vi
Message 3 of 13
(4,389 Views)
More information:
Linux Fedora 9
And the Visa configuration vi
Message 4 of 13
(4,385 Views)
don't see anything disturbing so I guess that something else has been changed too.
Probably the lower level visa driver?
Message 5 of 13
(4,378 Views)
I install LabView 2011 in another computer and the result in the same.
If I add a delay of at least 30 ms between writing and reading works fine.
Message 6 of 13
(4,373 Views)
A typo error, is 2010 Not 2011
Message 7 of 13
(4,370 Views)
I guess that it is te underlying serial driver in linux that has difficulties, in principle your program is not to blame
Message 8 of 13
(4,362 Views)
Have you tried slowing down the communication? You may have an "iffy" cable, or noise being injected into the cable. Does the same thing happen if you use, say, a simple serial communications program?
Message 9 of 13
(4,352 Views)
After LabVIEW updates and the problem started I place a spy hanging on the line of communication and the data are good, no noise.
I test with simple serial communication between two computers. If the data has more than 10 characters and at least one FF. When reading adds an extra FF.
Message 10 of 13
(4,346 Views)
