Ez430-RF2500
Hi everyone,
I´m new on NI forums, but I´m here because I need some help on the kit EZ430-RF2500.
I was wondering if anyone have any tutorial which explains how can I program the KIT. When I say program, I mean that I need:
 -- The things I have to set(code lines and functions), in order to have the wireless comunication between access-point and the end-device.
 -- How I set the input and outputs on the device.
Another thing I need to know is the following, the only way to aquire data from this kit on LabView, is by COM port?
Thanks for your attention.
(3,153 Views)
Check the program manual of the Kit. Usually you can download it from the vendor website.
Check the interface the kit support and LabVIEW use NI-VISA to communicate with devices through Serial, GPIB, USB, Ethernet.
(3,142 Views)
