F250 AYARI NASIL YAPILIYOR
F250 MkII hassas termometre arızalıydı tamir ettim. ayarını yapmak istiyorum .direnç için ayarlıyorum dirençte sorun yok fakat sıcaklık ölçer
(507 Views)
F250 MkII precision thermometer was faulty, I repaired it. I want to adjust it. I adjust it for resistance, there is no problem with the resistance but the temperature meter
So you repaired a device. And now it doesn't work and there is no problem with the resistance!
What is the question? What do you want us to help you with?
Rolf Kalbermatter  My Blog
(474 Views)
