FTDI 2Dxx for NI Visa under Windows 8
I am using the FTDI 2dxx.dll for my acquisitoin board using VISA LV routines. However, I cannot see my COM Ports when I run it under Windows 8, although it works well for Windows 7. What can I do to see my COM ports under Windows 8?
Regards
Daniel
(5,220 Views)
Are you able to identify your board in Windows Device Manager? If so you may be able to create a VISA driver for it using the following guide:
http://www.ni.com/white-paper/4478/en/
Have you downloaded and installed the latest version of NI MAX?
Rob B
FlexRIO Product Manager
(5,195 Views)
Creating a VISA driver would require obtaining all of the low level USB functions from FTDI and the port would no longer appear as a com port.
Instead of installing some mysterious version of MAX, it would be more appropriate I think to check the version of NI-VISA and install the latest version of that.
(5,190 Views)
Thanks for your response. I have now downloaded the lastest FTDI drivernad compiled those in my programme, as well as the lasted NI VISA Runtime. Now its working. Daniel
(5,175 Views)
I am able to identify my board. Now I have downloade the lastest FTDI driver for Windows 8 as well as the VISA RunTime from NI. Now its working. Thnaks Daniel
(5,173 Views)
(5,172 Views)
