Facing Hex 0xBFFF00A0 error in VISA
I am using PXIe 8820 controller. In MAX i want to configure VISA to route the front panel trigger to the backpanel trig lines (TTL0...TTL7 ect).Every time i am mapping in VISA erro occurs as "VISA:  (Hex 0xBFFF00A0) The value specified by the line parameter is invalid" How can i map the trigger(front panel) to backpanel.
(4,625 Views)
That sounds like a job for NI-Sync, not VISA.
(4,617 Views)
