Facing Problem With PCAN DLL after creating installer
Hi
I Have Developed to Test The CAN Hardware.
I am Using third party USB to CAN device (Phytec PCAN)
To communicate with PCAN device I have Used PCAN_USB.DLL
I have Tested My Code with the hardware. It Works Fine.
Then I Have Created EXE and Installer. and Install on the other system ( LabVIEW is not installed on that system). But it is not communication with the Hardware.
If I run the EXE on the system (where LabVIEW is installed) then EXE is communicating with the hardware.
Please guide me for the same. LabVIEW version - LabVIEW 2009
Please treats this on urgent Basis
Regards
Prabhakant Patil
Regards
Prabhakant Patil
(3,811 Views)
Have you added the LabVIEW Real-Time engine in the installer?
(3,793 Views)
I think sumit.sen means the run-time engine. That is required but so is your third-party diver. What exactly did you include in the installer? Is this dll included? Where did you install it?
(3,783 Views)
