Fail to select output 2 & 3 for HP6623A
I have a problem to select & set voltage on output 2 & 3 for HP6623A. I believe already installed a correct NI driver coz success to set voltage on output 1. Does anybody show me with some example using labview 7.1
(3,741 Views)
Hi yanz,
Can you provide me a link or copy of the driver and the program you are using? I was unable to find this specific model on the instrument driver network. Had you given the model name correctly?
Best Regards,
Joshua de la Llana
NI ASEAN
(3,714 Views)
Hi Joshua,
Simply refer to attached for the HP6623A connections details that I've made.
(3,693 Views)
I don't have the instrument and with IVI, it's difficult to understand what the code is doing. I would recomend that you first verify you are getting a response back from the self-test function. You might also need to wait before running the next function in order to make sure the self-test is complete. You should turn on NI-Spy and look at the commands being issued. Once you have the NI-Spy trace, you can compare the commands to what is in the manual. Do you have a problem with running the example for channel 1?
(3,672 Views)
