Fast Data acquisition (3kHz) with a Tektronix (TDS7104) scope
My task is the following: I have to grab programmatically few hundred nanosec. long signals with 1ns resolution (2-300 data points/frame) arriving on two channels to the scope. The challenge is that the rep rate of the signals are 3kHz! Currently I’m doing this manually using the Fast Frame segmented memory of a TDS 7104 Tektronix scope. This feature allows me capturing signals up to 160 kHz rep rate in the acquisition memory of the scope. With 2-300 data points/frame I can grab 7-8000 frames on two channels+trigger channel, which is enough for me.
My question is: How can I do this programmatically? How can I grab programmatically 7-8000 frames to the acq. memory and save them to a file. I’m programming in Labview but not in C.
I called Tektronix and it was advised to develop the software directly on the scope without any GPIB. I’ve researched on NI.com and it seems that the best would be would be to use NI-VISA. I haven’t tried the instrument driver for the scope just downloaded but it seems that it is not suitable for my application.
The final goal with such a software is to automatize our measurements by repeating this data acquisition sequence 20-30 times and between each sequence move an OWIS stepping motor via the USB port of the scope. Therefore between each acquisition sequence the grabbed 7-8000 frames should be written into a file.
It is also important that the whole measurement should be as short as possible. Tektronix engineers advised me not to use GPIB as it can slow down the whole process.
(3,984 Views)
It seems that there might be an easy solution. Before posting the question I tried only the driver (tkdpo7k) provided for the scope by NI. It is a nice driver but one can use it only to control basic features. I’ve recently installed the driver for the scope (tktds7k)  from Tektronix and it seems that one allows a complete control over the scope. Even the fast frame feature is available that is necessary for my measurements.
(3,921 Views)
