Fast data transfer HP3458
I am in need of an example in C/C++ (I'm in Borland Builder but that's not the issue) that demonstrates the setup and
execution for fast data transfer from the HP3458 to the host PC.  I am running an experiment that needs to see changes
on a short time scale (sub millisecond).  The HP3458 manual is confusing in terms of how to convert the "DINT" output
format back to floating point.  If anyone has done this before I would appreciate a tip or two.
Thanks.
(4,253 Views)
Hello Baseg,
        There is a non-certified CVI Plug and Play instrument driver for your instrument that might give you a good starting point.
Cheers,
NathanT
(4,235 Views)
Nathan:
Thanks, I'll look it over and see if I can adapt it to what I am doing.
(4,227 Views)
