Fast mode sr850
I wonder if someone used the function of FAST MODE SR850 lock-in amplifier to provide some source of information for the parameters that need to function.
(3,438 Views)
Hi Vanfer,
About what you are asking, I found a PDF document with some information that could be useful:
http://www.thinksrs.com/downloads/PDFs/Manuals/SR850m.pdf
Also, you can get some help using the context help. This will tell you a little bit about which entries do you need.
Also, I´ve found this forum in which there is another guy using SR850, you might be able to ask him some more specific sutff.
His/Her username is ustajee, and this is the forum I found: http://forums.ni.com/ni/board/crawl_message?board.id=140&message.id=39287
I hope this helps.
Regards
Luis Elias
NI VeriStand and HIL Product Manager
(3,397 Views)
