FindLstn Problems.
I am having problems with the FindLstn command. My code works fine under Win98, but when I run the same code on Windows 2000 there is about a 8-10 second delay for the FindLstn command. No errors are returned and the program runs fine other than the delay. Any suggestions?
(4,326 Views)
You could try:
-Using ibln instead
-Reinstalling NI 488.2
Windows 2000 also has options for application boosting that could be interfering with your application depending how you are programming and making calls.
See Performance Considerations for LabVIEW on Windows 2000
Ray Kong
NI Applications Engineer
(4,326 Views)
I believe the 1.x Windows NT driver was slow at performing the FindLstn protocol. The 2.0 version of the driver should be faster. I recommend downloading it from ni.com and trying it.
(4,326 Views)
Thanks for your suggestion, but I am using the old driver because the 2.0 driver doesn't support my old hardware. I have an ISA board, and the 2.0 drivers only support the PCI boards. Do you have any other suggestions? Thanks in advance.
(4,326 Views)
