Finding an .inf file for the NI AT-GPIB/TNT
I am trying to install the NI AT-GPIB/TNT using the ARS Technologies USB2ISA-SL (http://www.arstech.com/item-USB-2-0-to-ISA-card-slot-version-usb2isasl.html). Unfortunately the software provided for the USB2ISA-SL requires me to manually load the driver for the AT-GPIB/TNT and I need the .inf file for the card. Is there an easy place to find the .inf file? I have been searching through the software for the AT-GPIB/TNT and I have not been able to find it if it is there at all.
-Brian
(3,265 Views)
Hi Unywin,
Please go to the link below to download the version of the NI 488.2 driver that supports your software if you haven't done so yet. You will need to find the version that supports your software and operating system. For example, NI-488.2 version 1.7 supports AT-GPIB/TNT and Windows 95/98/2000/XP.
Once you have it installed on your computer, the Inf file should be located in your system 32 folder. If you are still having trouble finding this file, I would recommend going to this third party website and download this useful search engine. As the name implies, it will find every file type and its location on your computer.
http://www.voidtools.com/
I hope this helps.
Josh L.
(3,253 Views)
