07-20-2007 03:23 PM
> we think that your nifgen installation may not be complete.
> Did you install nifgen before or after installing LabVIEW?
After. 8.2.1 has been in use on that machine 2-3 months now, and I installed FGEN just a couple days ago after installing the PCI-5421 and verifying it worked via MAX test panel.
> Please try to run the nifgen installer again and let me know if this helps.
No change.
As a side note, after installing FGEN, the FGEN VI's did not appear on the block diagram palatte. I could find .mnu files in the 7.1 and 8.0 LabView directories, but not in the 8.2 directory. Had to copy them over manually. It was as though FGEN wasn't aware of of doesn't accomodate installation on an 8.2.x version of LabView.
Mark Brueggemann
Albuquerque, NM
07-20-2007 03:45 PM
