Fireberd 6000A serial driver
Does anyone have a serial driver for the Fireberd 6000. There is only a GPIB version on NI's web. Thanks
(3,530 Views)
That driver was programmed with VISA, so converting it to a serial program shouldn't be too hard. It depends on the method the instrument uses to send messages. If the serial side uses termination characters, then conversion will be simple. You could also hire an Alliance Member to convert the driver for you.
Alliance Member Directory
http://www.ni.com/alliance/alliance_member.htm
(3,530 Views)
