For the Watlow F4.lvproj VIs I don't see anywhere in there to set the BAUD rate.
Many of the posts from others suggest that setting the BAUD rate to 9600 or 19220 is best. But I don't see any parameter settings for BAUD rate in ANY of the VIs. Anyone have an idea where to look? Thanks...
(566 Views)
Accepted by topic author johnsonsite
Try:
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(557 Views)
