Frame to write for RS485 communication with Keller pressure sensor
The transmitter works on ModBus. Thank you.
Message 11 of 16
(1,565 Views)
Can you also attached the sub VI's in your code and I'll give it a try? Thank you for your help.
Peter
Message 12 of 16
(1,565 Views)
Sorry for that. Here it is.
Kees
Message 13 of 16
(1,536 Views)
The loopback test was successful (i.e. there was a successful output in the read buffer indicator). How would you propose making the leap from using this loopback vi to getting the output voltage and/or pressure reading from this pressure sensor? I've attached the communications manual for this particular sensor. I understand I'm asking a lot, so as little or as much information you can provide is much appreciated.
Thanks.
Message 14 of 16
(1,529 Views)
If you want to have a full blown ModBus communication and your device only uses standard ModBus commands you could use the ModBus lib from NI.
I don't use it because I have device with dedicated commands and I want to have more control over the communication (for error finding, debugging devices, etc.)
If you want to do it with your own VI's we can start with a simple read of the first register. In the manual 4.5 at page 9 describes the register read. In 4.9 I take the pressure of sensor 1. (slave 1)
The command for this: 010300020002 + CRC   slave 1  -  command 03  -  register 0002  -  read 2 registers.
The result is something like this: 0103 0400 0116 80A4 33   slave 1  -  command 03  -  4 bytes -  00011680 is the data you want + CRC
The 32 bits data is a FP number.
The attached VI is just the Loopback with some changes.
The next commands (write register, read/write multiple registers) are basically the same. But first this one.
Kees
Message 15 of 16
(1,522 Views)
Thanks so much. With your help and a couple of hours I've been able to piece together something serviceable. I appreciate your help.
Message 16 of 16
(1,509 Views)
