Frankonia FC 02 antenna mast and turntable controller
When you tried to install NI-VISA, isn't there an option to install just .NET support. It's been a while since I did this but I thought this was an option.
Message 11 of 15
(2,197 Views)
Hi ku_ku,
Currently, I am also interested to create my own app to control the turn table and antenna mast of FC02
Did you manage to dechiper the commands?
I would be more than happy if you would like to share the codes.
Thanks in advance.
Message 12 of 15
(2,125 Views)
I've done this so far ago.... couple of vi. Give a note if this is not enough, I'll ran to \lab an copy it from test PC- where it is still runing.
Message 13 of 15
(2,121 Views)
Hi Ku_ku,
According to the official discussion rules (rule #3 in the link below) you shouldn't post to old discussions, but instead create your own new post. This helps you, since new posts are more likely to be seen and get answered. Please make a new post for your controller question
Forum rules: http://forums.ni.com/t5/Getting-Started-on-the-NI/NI-Discussion-Forums-User-Guidelines/td-p/3164638
Message 14 of 15
(2,111 Views)
OK, rules are rules... nothing to complain.... 🙂
Message 15 of 15
(2,106 Views)
