Frequent crashs in NISE editor
We're currently evaluating the NI Switch Executive software for our test benches.
We tried the editor to create a sample switching system (3x RD126030 MUXES + 2x RD126040 Matrixes).
The results seems to be very satisfactory except for the following issues :
* During this test, numerous crashs occured (mainly after removing a device from an existing configuration).
* We also found several graphic glitches and display error in the editor user interface.
* Furthermore, we found so unexpected behavior which disappeared after rebooting our operating system (Windows NT4).
Our questions are :
Is the evaluation version an old / downgraded version ?
Is there a patch to solve those problems ?
Or is there a new version in the work
which will solve those issues ?
Sincerely,
Rémi THEVENIN
(3,150 Views)
Remi,
I have not had much experience running the Switch Executive Evaluation version, however, running the released version it seems to perform very consistently without the behavior described above. Typically the evlauation versions are based off the full version with several advanced features removed. My thought woud be that some of these features are effecting the performance.
Best Regards,
Chris
(3,150 Views)
