Function Generators
Once I got a USB adaptor and plugged it into the computer it worked. The computer recognized it. I recieved the software for it and an english manual so things should be looking up.
Message 11 of 16
(3,522 Views)
The pc can only recognize the USB-serial adapter. It cannot recognize the instrument itself. That is something you must do manually.
Message 12 of 16
(3,514 Views)
Clueless again.
I would hope the computer would recognize the USB-RS232 adapter.
The function generator is totally different issue.
Software for it? How is that going to be helpful?
Message 13 of 16
(3,503 Views)
Maybe the RS232 commands and it's parameters are noted in the manual....  and if not, a little reverse engineering by sniffing the RS232 port while using the software is an easy way to go 🙂
But peeking into a foreign language manual, I found parts that looks like a RS232 command description... so some simple VISA commands should do the job.
Greetings from Germany
Henrik
LV since v3.1
Message 14 of 16
(3,485 Views)
You may be able to figure out the foreign language manual, because you know what you are looking for.
I am not sure the same can be said of the OP.
I find it oddly coincidental that he has now obtainedthis so-called software and an English-language manual.
Message 15 of 16
(3,481 Views)
Here is the English manual with the command protocol and commands.
-AK2DM
Message 16 of 16
(3,457 Views)
