GPBIB Timeouts with PCI card
I'm getting timeouts when using a PCI card but everything is OK with a PCMCIA card.
I believe this is related to bus speed but it doesn't improve when I change the timing.
I am using driver 2.5.2 is there an updated driver for this problem?
(4,094 Views)
What model PCI card?  This often happens when swapping from NI controllers to controllers manufactured by other vendors.
(4,076 Views)
Hey Dave,
Would it be possible have a look at your code? Sounds to me like that card is waiting for a signal but not recieving it?
Regards
Andrew George @ NI UK
(4,053 Views)
thanks for both responses.
The Card is an NI PCI.
I don't have the code but attached is an NI spy log in csv format with -410/420 error
Any insight would be appreciated.
Bear in mind this error only appears with a PCI card, PCMCIA is fine.
(4,049 Views)
Hey Dave,
There is another forum post I would like you to check out, the error can be caused by improper termination. Check this post out and let me know if it helps:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/GPIB-error-420-with-LabVIEW-and-232CV-A/m-p/1...
Regards
(4,003 Views)
Thanks for the respone.
We are looking into the termination as not being handled correctly when we get a system error but it's the system error - timeout- in the first instance that is the problem.
I will let you know how things are going.
Cheers.
(4,001 Views)
