GPBIP Port in Agilent 34401A
Dear NI
Hello. I have downloaded Agilent 34401A from the ni.com. It has only COM! for VISA connection. I wanted to use GPIB.
Kindly advise.
Best
Karan
(3,431 Views)
The driver supports GPIB, RS-232, Ethernet, and USB. So, if you have a GPIB board, it's connected to the instrument, and done a scan for instruments in MAX, your connection should show up in the list of available VISA Resources.
If you do not have an NI board, then you will have to do a few different things in order to get things to work. Search the board for 'Agilent GPIB' as an example if that's the case.
(3,424 Views)
