GPIB-232CT-A Unrecognized command succeeds Error 17 ECMD
I have been communicating to a GPIB-232CT-A using read/write C functions. The lack of a serial driver for 2.6 Linux kernels is a big pain.
I am able to read and write data seemingly successfully. but a 'stat n' returns Error 17 <ECMD> after every read, but not write. The read format is fairly simple, and succeeds. The documentation on ECMD error indicates I made a typo.
Can anyone give me insight into what could be happening?
here is an example
wrt #8 13\n*IDN?\r
rd #80 13\r
<reads the IDN data successfully>
stat n
ERR,END,CMPL,REM,CIC,LACS
ECMD
NSER
33
N0pes
(4,203 Views)
Hi Nopes,
I had a look through the 488.2 help and I am having trouble figuring out what your "stat n" command is supposed to do, where did you find this command?
Scott McCaig
(4,162 Views)
Thank you for taking the time to help.
Here is a link to the user manual. stat n is located on page 88.
-N0pes
(4,160 Views)
N0pes wrote:
here is an example
wrt #8 13\n*IDN?\r
 I do see an error in your write syntax, it could be that the error is not detected until it starts processing the read. In the above wrt command, you specify a length of 8, but your string is only 5 characters long. The count is optional on the wrt command, so I would just omit it unless your string needs to include a carriage return as part of the data.
If you do need the carriage return as part of the data, then the command should be:
wrt #6 13\n*IDN?\r\r
I hope that solve the problem,
Jason S.
(4,073 Views)
