GPIB-232CT-A serial protocol
Pertaining to the programming of the GPIB-RS232 controller, our end RS232 device is not a Windows nor linux based so no NI drivers can be installed. The RS232 device will only be a listener or listener, never a controller. So it seems like either G mode or D mode would be what we can use it under with D mode sounding like what we should use. What we can't determine from the online documentation is how, without installed drivers, would the RS-232 device instruct (C Programming) the GPIB-RS232 to activate the SRQ line. We want to be able to control that.
Message 11 of 14
(2,043 Views)
marlanbrando,
The GPIB-Serial Converter acts only as a device that converts GPIB commands to Serial commands.  Your program on the controlling end will have the ability assert and deassert the SRQ line.  The GPIB-Serial Converter is only a converter.  The only software you will need to use is the installation CD that comes with the GPIB-Serial Converter.
A_Ryan
AES
Message 12 of 14
(2,017 Views)
Does NI-Spy work with GPIB-232CT-A?  It doesn't appear so.  We need to capture the call traffics but have been unable to.  Is there something available?
With the new GPIB-RS232 operating in GPIB-232CT-A compatible mode, does it require device drivers or does GPIB-RS232 acts as proxy still like the GPIB-232CT-A?
With the new GPIB-RS232 device operating in GPIB-232CT-A compatible mode, will NI-Spy work?
Thanks.
Message 13 of 14
(1,965 Views)
marlanbrando,
Based upon you original post for setup # 2:
Windows XP machine <--- serial port ---> NI's GPIB-232CT-A   <----- GPIB ---->  { item B } <serial> <----> custom software
NI-Spy will pick up the serial commands between Windows XP machine and GPIB-232CT-A.  The reason is because the converter takes commands and then performs those actions on the bus.  This being the case, you would not expect to see the GPIB commands.
A_Ryan
AES
Message 14 of 14
(1,938 Views)
