GPIB Analyzer-Error
When I run the GPIB analyzer in the Measurement and Automation Explorer Window I receive an error that states
"MISSING CARD ERROR -supported GPIB+ interface not found".
I just wondering what this meant and what are the consequences as well as how to correct this error. Any help will be appreciated.
thanks
(3,267 Views)
What GPIB card do you have? If it shows up in Measurement and Automation Explorer (MAX) as PCI-GPIB and not PCI-GPIB+, the GPIB Analyzer will not work. Only GPIB+ boards support the GPIB Analyzer. If you have a GPIB+ board, has the analyzer worked before? Have you changed anything since the last time it functioned correctly for you?
Logan S.
(3,246 Views)
