GPIB Analyzer on PCII GPIB Card
Is it any release of GPIB Analyzer that supports PCII GPIB interface card? Is it any other NI software for PCII card that enable monitoring and manually setting individual data/control lines on GPIB bus from the PC with Windows operating system?
(3,476 Views)
The GPIB-PCii acts purely as a GPIB interface board and does not have the necessary hardware on its circuit boards to provide the type of GPIB analyzer operations that you are looking for.
NI produces a number of boards that have the GPIB analyzer hardware built in (AT-GPIB/TNT+, PCI-GPIB+ and PCMCIA-GPIB+). However, be aware that there are certain OS limitations when it comes to using these boards. For example:
PCI-GPIB+ Windows NT only
PCMCIA-GPIB+ Windows 3.1/95/98 only
So unfortunately you will not be able to achieve what you wish to do with your current GPIB board and there are no software updates/fixes capable of turning the GPIB-PCii into a GPIB controller/analyzer. I guess the AT-GPIB/TNT+ might offer the best upgrade path as it is an
ISA board and supported under a wider range of operating systems that the PCI-GPIB+
More information about the boards mentioned above on the GPIB product pages:
http://www.ni.com/gpib
or speak to NI directly
Jeremy
(3,476 Views)
