GPIB: Data transferring to CMW 500
Hi I just started to learn CMW 500. I got a GPIB-USB-HS to connect between CMW 500 and my labtop. I would like to transfer data to CMW 500, but I am not really sure what initially need to do. Does anyone can give some idea or way to transfer data ?
(4,695 Views)
Transfer data?
I would suggest reading their manual.
(4,688 Views)
You also need to provide the programming language you will be using. The vendor should also be provided. I would guess an R&S but there should be no guessing required.
(4,684 Views)
