GPIB-ENET/1000 Installation Troubles
I am running into problems trying to install a recently purchased GPIB-ENET/1000 unit. When I run the GPIB Ethernet Wizard the device is not detected. Selecting "Refresh List" produces nothing.
I've tried to use NI-Max to see if the unit is detected without any luck.
I am running Windows 10 on a Dell OptiPlex 3060. The GPIB-ENET/1000 is connected directly to the computer with a straight-thru ethernet cable.
I am running a static IP configuration (TCP/IPv4) as follows:
IP address: 192.168.10.206
Subnet mask: 255.255.255.0
Default Gateway: 192.168.10.1
Preferred DNS server: 192.168.10.12
(Windows is forcing me to make an entry - this is what our sys admin set it to)
I don't think I have an issue with my cable or Ethernet adapter as I am able to communicate with other devices without issues.
Can some one clue me in as to what I'm doing wrong? We can not support DHCP since we will eventually have other devices on the network with fixed IP addresses and require that our control applications be used without the need to reconfigure,
Any help greatly appreciated!
Thank you!
Message 1 of 1
(2,939 Views)
